ProfilerX v1.0.3 - tự động chuyển profile theo thời gian định sẵn (Toysoft)
Thảo luận trong 'Phần Mềm - Công Cụ Tiện Ích' bắt đầu bởi phatlnp, 20/6/11.
    Với ProfilerX cho phép BB của bạn tự động thay đổi Profile, Bluetooht, Wifi một cách nhanh chóng.
    Bạn hoàn toàn có thể đặt thời gian cho chiếc BlackBerry của bạn ở Profile Normal khi ở cơ quan, và khi về nhà, BlackBerry sẽ ở chế độ Silent, quá tuyệt vời!
    +Tính năng:
    - Hỗ trợ lên đến 64 profile khác nhau
    - 4 chế chộ khác nhau: Time Schedule, Location base, Bluetooth and WiFi
    - Hỗ trợ Profile tự tạo (Custom profile)
    - Có thể đặt hình nền và nhạc chuông cho từng profile khi tự chuyển
    English information:
    ProfilerX is an application that lets you automate system sound profile switching during the day. You can schedule profiles each day to change from one profile to another. Each profile you set the time to switch, the days which the profile will be active eg: Monday to Friday. Optionally you can set to change a new Wallpaper on the HomeScreen and change a ringtone.
    ProfilerX also allows you to use the Cell Tower information, Bluetooth connected devices and WiFi hotspot to switch sound profile.
    You can configure ProfilerX to switch to a different profile when you arrive at the Office, when the BlackBerry is connected to the car handsfree Bluetooth or when the BlackBerry is connected to the WiFi network. You can use any combination to control profile switching.
    With ProfilerX you have total control over Bluetooth, Wifi and Mobile network connectivity. You can tell ProfilerX when to turn on and off BT, WiFI and Mobile Network. Note: when turn on and off Bluetooth ProfilerX will NOT work if the BB is in the Holster or keyboard locked.
    Note: Due to BlackBerryOS security ProfilerX can not switch profile when the device is in the Holster, keyboard locked or password locked or flip closed on the Style. You will receive a vibrate for these events. ProfilerX will automatically switch profile when you unholster or unlock the device.
    The workaround for keyboard or screen lock is to use a 3rd party keyboard or screen lock. If you have Touch screen BB like the Storm or Torch you can get PatternLock Lite the free version. For non-touch screen BB you can use almost any 3rd party keyboard locking app with ProfilerX.
    Note: Make sure permissions are all set for ProfilerX in the Options-Application and OS6 in Options-Device-Application Management.
    ProfilerX can not switch profile if the your BlackBerry is in Standby mode.
    Features
    * Support up to 64 scheduled profiles
    * Four different profiles: Time Schedule, Location base, Bluetooth and WiFi
    * Support Custom profiles
    * Selective days to activate profile
    * Optionally set a different Wallpaper or Ringtone when a profile is switched
    * Optionally vibrate when device is in Holster or locked
    * Manage Bluetooth, Wifi and Mobile network with each profile. eg: turn off Wifi, BT or Mobile network when not needed
    * Very easy to use
    Bác nào cần k@y thì PM hộp thư của diễn đàn nhá (nhớ để lại mã PIN)
    cucchung thích bài này.
  2. TheMen
    TheMen
    giống cái ScheduleRingger của mình quá, nhưng hình như cái này hay hơn (có thêm lập lịch cho WiFi,BlueTooth). Thanks Bác chủ
  3. phatlnp
    phatlnp
    bác thanhvbnd nhận hàng nhé, đã gửi k@y cho bạn trong hòm thư của diễn đàn :twins:
  4. khazip
    khazip
    có chạy ngầm ko bác ơi :D
  5. javelin
    javelin
    Cảm ơn bác, bác xem mật thư nhé
  6. thanhvbnd
    thanhvbnd
    chạy ngầm bác à! tất nhiên liên quan đến ấn định thời gian bắt buộc phải chạy ngầm rồi
  7. phatlnp
    phatlnp
  8. thanhvbnd
    thanhvbnd
    nhận xét sau khi đã test nha: không tự chuyển được profile khi lock bàn phím kể cả stanby :D...lại phải gỡ ra hixhixx..chạy ngầm cũng ko tốn pin đâu thưa các bác
  9. phatlnp
    phatlnp
    Còn về Switch profile, bạn chỉnh profile như thế nào? Chọn đúng như trong hình ở bài viết đầu tiên là được, mình đang xài đây, rất good ( 6h sáng: là profile Normal, tới 20h thì tự động chuyển qua profile Silent, tới 6h sáng hom sau tự chuyển qua Normal)
  10. BlackBerrier
    BlackBerrier
    Tìm cái này bữa giờ, thanks Phát ^^
