iNEW7 - OS6 Compatible : 9300, 9780, 9800( Theme TOP appworld 3.99$)
Thảo luận trong 'Giao diện - Themes' bắt đầu bởi acma.bber, 1/8/12.
    ON SALE FOR LIMITED TIME ONLY
    (REGULAR PRICE $3,99)
    ***PLEASE WRITE A REVIEW & RATING NOW***
    iNEW7 gives you a new feel of User Interface ( UI ) experience on your BlackBerry® 7 with almost skinned custom icon set.
    Would love to know how do you feel of the iNEW7 Themes as a review.
    OS6 : 9300, 9780 ,9700, 9800
    Features:
    Custom curved rectangle with illumine effect ICON SET
    Unique AM/PM display ( set time to 12hours mode )
    MENU and PANEL background are transparent
    Wallpaper friendly
    Custom Battery & Custom Signal
    Clean, fast, functional, stylish and easy to use
    Homescreen status
    Support landscape mode.
    All features on potrait mode work perfectly on landscape mode.
    Check other Walker Themes at :
    http://appworld.blackberry.com/webstore/vendor/10710
    NOTE:
    -We strongly reccomend a REBOOT/RESTART once your theme has activated or installed.
    -OS7 themes are currently in Beta, so any issues encountered will be fixed rapidly via updates.
    -The Calling screens are the default one and you may encounter other bugs that will be fixed as soon as possible
    -All screenshot wallpapers are for illustration only or to describe this theme is wallpaperfriendly, they are not included in the themes.
    -Please make sure that you select the right device and OS version (to check your OS go to Options- About).
    -Please see the screenshot and check the features info 1st before purchasing because we don't accept any personal modification or request.
    -Subsequent claims can not be taken into account! Also check screenshots first and then select the theme you want! Screenshots can be found in BlackBerry® App World™.
    -Remember to perform a battery pull after installing a new theme.
    -You MUST have a data plan/internet access on your BlackBerry in order to install themes.
    Demo:
    acma.bber
    acma.bber
    #1 acma.bber, 1/8/12
    secretaryofcondao and Zerostar like this.
  2. secretaryofcondao
    secretaryofcondao
    Theme rất đẹp, nhưng lại mang phong cách Iphone, không phù hợp lắm với BB. Nếu các icon là của OS7 thì tuyệt.
