BlackBerry cập nhật OS 10.3.2.2204 (SR 10.3.2.2134) cho Beta Tester trên Beta Zone
Thảo luận trong 'ROM – OS/ Hệ Điều Hành Cho BlackBerry 10' bắt đầu bởi huynhgiathien, 10/6/15.
    Hôm nay, BlackBerry đã tung ra phiên bản cập nhật OS 10.3.2.2204 (SR 10.3.2.2134) cho Beta Tester. Đây là bản mà mọi người trong số chúng ta nếu không là Beta Tester đều mong đợi vì nó là bản Build 4 số. Anh em nếu đang là Beta Testter thì sẽ thấy nó trên Beta Zone.
    Những thay đổi trong phiên bản này:
    • [Active Frames] Minimized Apps content in active frame appears distorted and stretched
    • [Android] Skype may close unexpectedly
    • [BBWorld] Unable to view reviews in BlackBerry World
    • [Browser] In some cases, the browser will close unexpectedly
    • [Browser] Tab list may not minimize when tapping active webpage content
    • [Contacts] In some instances, you may not be able to share a Contact: "You can not share data from this contact"
    • [HUB] Classic - in some instances, not all of the speed triage options can be highlighted via the trackpad
    • [HUB] In some cases, after deleting a message using speed triage, a blank entry is left in its place
    • [HUB] In some instances, a deleted conversation in the HUB will re-appear for an instant, then disappear again
    • [HUB] Messages may not open when in conversation mode
    • [MULTIMEDIA] The Music app may sometimes return the error message "The media library can't be accessed. Please try again later or restart your device if the problem persists"
    • [Notifications] Level 1 Alerts does not play sound and vibrate notification
    • [Performance] A delay may be experienced when multiple apps are opened or multiple actions are performed in the HUB
    • [Phone] Poor HUB performance after ending a Phone call
    • [Settings] Device Storage details screen shows incorrect data
    • [SW Update] Sometimes, a device restart could take up to 15 minutes immediately after a wireless update
    • [Swipe to Wake] Device wakes too easily when in pocket
    • [Text Input] "Hi" is auto-correcting to "HI" on pressing Space Bar.
    • [Text Input] First word always auto-corrected to ".com" after toggling input language from Pinyin to English
    • [Text Input] In some instances, duplicate characters are being injected by physical keyboard
    • [Text Input] Prediction bar flashes when inputting spaces in Chinese pinyin input mode
    huynhgiathien
    huynhgiathien
    #1 huynhgiathien, 10/6/15
  2. MrLam
    MrLam
    hóng cho pp, không biết có thêm chức năng zoom và lướt pictures không nữa
  3. romeo1590
    romeo1590
    ngon đã lên bản 4 số , vậy là sắp chính thức rồi
  4. Nông Dân
    sắp chính thức rồi, chắc oslo ra mắt sẽ chính thức =))
  5. tungmbi
    tungmbi
    Bạn nào post bài này hơi lười dịch. Vì như vậy sẽ bị hạn chế,những bạn k biết tiếng anh sẽ k hiểu. Các bạn có thể google dịch rồi chỉnh sửa xíu là xong. Hy vọng là các bạn rút kinh nghiệm vc này
    target46k2 and ahoangqn like this.
